Ok...SO ive just used TMPGEnc to make a DVD, and the output files are M2V and WAV.....How do i now get them onto my DVD-R? I use Nero Vision Express 2.... Thanx if ya know the ansa!
PS: Is there an easier way to get all my AVI's onto a DVD-R and have good quality? Other than TMPGEnc 2.5???
The least steps possible if ya can!
MXMaster.
You need to Author the video. It would be better if
you converted your WAV to MP2 or AC3 first, because it
will take up lots of room as is.
Does NeroVision have a Help button ? -
With most authoring tools can you select a separate audio track. I think nerovision supports that also.
Like add the video and then select an audio source like your wav.
Transform .m2v +. wav to full MPEG-2 dvd spec file?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 2Last Post: 14th Oct 2011, 09:13 -
How to mux a m2v file with 44.1khz, 16-bit wav?
By seven_deuce offsuit in forum Newbie / General discussionsReplies: 2Last Post: 24th Apr 2011, 23:25 -
have m2v+wav and chapter points, what's next?
By shun in forum Authoring (DVD)Replies: 3Last Post: 15th Aug 2008, 10:21 -
Authoring m2v,wav and idx/sub
By Soixante in forum Authoring (DVD)Replies: 5Last Post: 12th Feb 2008, 10:26 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08
