Hello everyone,
I just ripped the audio from a DivX movie, and tried to encode it with toolame, and it crashes at about half, I try again and crash at the same place. I've had this problem before so I thought I'd just ude dbPowerAMP.
Well, turns out I'm low on free space on C: , and from what I found there was no way to change the temp folder for dbPowerAMP. Well, I then rip the audio into 2 smaller parts and encode each one separatly.
Now my problem is, is there a way to merge them together to one .mp2 file? Or will I have to cut the video into 2 pieces after encoding it to VCD, then multiplex them together?
Sound Forge has the ability to merge sound files (yes, MP2 files too). But I'm not sure if it's shareware, but for sure, it's not freeware.
http://www.sonicfoundary.com
merge 2 subtitles files
By massimo.max in forum SubtitleReplies: 15Last Post: 29th Dec 2012, 02:35 -
Merge multiple audio tracks from different files into 1 video file - sync
By heinza in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2012, 03:29 -
Extract .m2v and .mp2 files
By geohei in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2010, 12:42 -
How to merge wav files ?
By Benjy in forum AudioReplies: 7Last Post: 31st Jul 2010, 04:41 -
Merging MPA video and MP2 audio files
By makf in forum Newbie / General discussionsReplies: 2Last Post: 7th Jul 2009, 19:13
