  1. Ok... if while trying to backup and transcode one of my dvd's, and it says its gonna be say "77% quality"... then I go to the next page and "uncheck" certain options.. like dts sound.. directors comments... and maybe even AC/2 sound... now when I step backwards.. my percentage hasn't changed?..
    so the question is.. have I simply removed some features without increasing quality.... (It appears the disk is not quite fully burned by visually looking), or is it just a bug and it doesn't show you that he quality is now going to be higher?....
    why give us a percentage bar if we are helpless to alter its level?...
    thanks for any insight.... I love clonedvd, but this is the only nusience for me..
    thanks
    Don't do it, if you can't chew it!!!
  2. Banned
    May 2003
    Massachusetts
    This is the biggest "missing feature" in CloneDVD right now. Olli has had to adjust to the fact that a HUGE percentage of his users want more control over CloneDVD than they had over CloneCD.
    It'll come, give him time.
    - Gurm
  3. I agree.. it will come.. but in the meantime... I am literally cataloging my backups as to "what percentage" of the original they fall under... I don't know if I can belive the percentage bar "after" I have made modifications?...
    I also need to know this to help determine "if" it is cost effective to make the changes?????
    If in reality I am not upgrading the quality by knocking off stuff.. then why do it?..
    I am suspicious .... I wish I know for sure...
