  1. i'm running DVDSP 1.5, and i'm wondering what your opinions are on the new software, and particularly the new mpeg-2 encoder. i believe it's called "compressor".
    can this encode half-D1 resolutions, and in VBR?
    thanks,
    -Mark
    Swim with me
    And we'll escape
    All the trouble
    Of the present age
    Finally free
    Apr 2003
    DVD Studio Pro 2 is da bomb!!!
    I love it. It comes with compressor and it has the vbr and all that.
  3. Member OmegaSupreme's Avatar
    Oct 2003
    Fort Lauderdale
    Compressor does support 1 & 2 pass vbr encode but not half-D1. DSP 2 dosen't support half-D1 files at all.
  4. There is a new update posted on versiontracker.com for those that are using 2.0
  5. Originally Posted by OmegaSupreme
    grr... whyever not? this is a rather large oversight on apple's part.. after all, half-D1 is part of the DVD specification!
    Swim with me
    And we'll escape
    All the trouble
    Of the present age
    Finally free
  6. On DVDSP 1.5.2 you can import Half D1 Mpeg2 files without problems...
    It's hard to believe that the new 2.0 can't... this format is on the Dvd specs!
    Or are u speakin' only about compressor?! (I tried it and, yes, It only encodes at full D1)
