I just bought a DVD burner (plextor 708a) , but I am connecting it to a RAID Controller. What are the jumper settings? My first RAID controller connection device...!
Why are you conecting the DVD Burner to the RAID controller? It should be connected to the IDE controller, yes?
It might not work. Some ide raid controllers don't support JBOD setups, only hard drives. What controller are you using? Anyway, there is typically not jumpers settings other that slave and master just like any ordinary ide controller.
Most Promise chipset controllers don't support ATAPI devices, but Highpoint chipsets usually do. -
Most Raid controlles are only for hard drives so there is a strong possibility you would not be able to connect your dvd burner to it.
SLICK RICK
Crucial M4 64gb raid or no raid?
By Stealth3si in forum ComputerReplies: 7Last Post: 20th Mar 2012, 05:13 -
RAID controller question...
By RogerTango in forum ComputerReplies: 12Last Post: 22nd Oct 2011, 00:59 -
Promise RAID Controller Help
By Ozzyjim in forum ComputerReplies: 3Last Post: 26th Feb 2011, 02:02 -
Need recommendation for a pci raid controller card
By mysts in forum ComputerReplies: 16Last Post: 4th Jan 2010, 22:03 -
Jumper settings for Hardrive & DVD burner
By CapeKO in forum ComputerReplies: 3Last Post: 15th Mar 2008, 21:41
