I capture from a PAL vhs at 25fps 640 x 576 resolution
until commercial break ..and get 4-5 segments
..well when I open the captured segments
in TMPGENC it sometimes sets the FIELD ORDER
to TOP or BOTTOM ...and they all come from the same tape.
This does not sound right to me.
What's the correct field order ? top or bottom ? I'm using PCTV RAVE
for capture (composite input) from VCR..this is confusing me.
Hi, i would say to use bottom (change it if it's set as top) because when you go into tmpg and u click settings(after you've closed the wizard) it's always on bottom so stick with that it's always worked fine with me. Then encode it as normal. Try that see if that waorks. Neil :P
i would recomend bottom as well, also, play with that litlle box that asks video movie/film movie..you can sometimes get better results
"If u cant eat it - u dont need it"
"Baby - If i dont hit it, Who will?"
"Why is Abbreviation such a long word"?
Field Order Question
By daz1976 in forum DVD RippingReplies: 2Last Post: 11th Feb 2010, 10:27 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 01:38 -
field order and cce
By cd090580 in forum Newbie / General discussionsReplies: 3Last Post: 17th May 2008, 17:11 -
Field Order Problem?
By GordRocks in forum Authoring (DVD)Replies: 3Last Post: 4th Mar 2008, 10:19 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 17:14
