Hi
I just got the dw-U10A the (oem version of sony dru500a) firmware 1.1d
I have P4 256 XP Pro
Nero 6.0.0.9
I burned already 2 dvd on dvd-r x4 with Nero and it turns out great with no problem ( it took about 15 minutes to burn 4.5 Giga)
But when I tried to burn data with nero I did not succeed.
First I got the message "can't burn at x4" after 2% of burning
I tried than at x1 it seemed to work but after an hour I got error
On the burned dvd I saw all the files but could not display them or copy.
I ruined 3 dvd-r in the process.
what seems to be the problem ?
Should I upgrade my firmware ? is this the problem , I tried to upgrade from the firmware page to 1.1.e but it did not detect my dvd
even that DriveInfo22 did, as Sony DVD RW DW-U10A 1.1D
Any help will be appreciated
Dr. Glass rafi
I assume you have an understanding of the different formats under Nero. Some people report problems with Nero, but I have used it for some time (Version 5.80) and it works fine for me. You might try Burn4Free (Check the 'Tools' section of this site) as an alternative for data disks. Data disks should be easy, but some of the experts here might be able to give you better Nero advice if you are still having problems.
Error messages burning data DVD using Nero version 6
By craigsb in forum ComputerReplies: 6Last Post: 27th Oct 2011, 09:12 -
dvd burning/convert program which burns both 4:3 and 16:9 for single movie
By vampelle in forum DVD RippingReplies: 7Last Post: 20th Sep 2010, 03:50 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
DVD Data Burning Query
By gilera in forum Newbie / General discussionsReplies: 17Last Post: 4th Feb 2009, 04:32 -
Burning data-dvd
By btkuehn in forum Authoring (DVD)Replies: 37Last Post: 9th Oct 2008, 19:55
