I have two hard drives, and since I will format everything and reinstall windows, I would like to do some changes to improve the performance of my captures (mainly to avoid dropped frames).
My first HD have 40gb 7200rpm, that is primary master. The second HD have 20gb 5400rpm, that is slave. I'm thinking to use the 7200rpm hard drive as dedicated hard drive for capturing, and install all the programs and OS on second HD. How it sounds ? Should I change something like, primary, secondary, slave connections too ?
Make the 20gb the master and install your operating system on that, and make the 40 gb a slave and use it to capture on.
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43
