I have a downloaded video clip that is multi-audio-track encoded. When I go to play in winblows media player it just plays the english on top of the french on top of the spanish :P. I figured out how to view it properly using Media player classic, but have no idea where to begin to convert this.
If i use Virtual dub to dump the audio will all the tracks come with it?
Is it possible to (wrong word coming up, but i'm a newb.) demux the audio tracks into the 3 seperate streams?
o yeah.. 1 more hurdle, the english track is AC3 (44100hz i think), while the french and spanish are Lame mp3 down-sampled to 32000hz.
Any clue as to where to begin?
Any good guides that deal with this?
Should I write one if I figure this out?
ok.. I think my problem is I don't have a proper AC3 codec installed.
Installing it now, hopefully this will allow virtualdub to dump the audio and I can deal with it from there.
I tried just converting with tmpgenc but it locks it up as soon as I load the file.
If anybody has any info please help. -
I have succesfully ripped the english audio track after getting the right codec installed, but now i'm having a problem getting tmpgenc to handle this task.
I tried frameserving the video and then loading the audio seperately, but it just locks up and says not responding, I would save the video out as an AVI but that would be 18gigs uncompressed, I would compress again, but it's already a crappy Divx and I want to retain as much from the original as I can.
If anybody has a suggestion I'm all ears. -
ok.. i'm an idiot.
had to process it in tmpgenc as ES files, wouldn't output a full mpg, i'll just multiplex them together after the encode and hopefully this will work.
So what have I learned by working through this problem on my own.
1. Nothing is impossible with google.
1a. No matter what you search for on google you will eventually end up at a porn site.
2. The shortest distance between 2 points is usually a twisting winding road with many hills.
3. RTFM
If anybody feels a walkthrough/guide would be helpful for this I'll do it, but it was pretty much straight forward once I figured out that tmpgenc doesn't like ac3 audio on my computer. -
Well that didn't work.
But a quick search of the guides and BLAMMO!! Thank you Baldrick!
Since I finally knew what I was up against, and what my major problem was I could intelligently search the guides for my answer.
In a word the answer was GoldWave.
Now my next question, since my sorce AVI has multiple audio tracks, and I only speak english this doesn't really matter to me, but what if I only spoke spanish and I needed to rip the second audio track out of the file, is this possible?
well back to the guides!
Dual or Multi Audio AVI with subtitles (MPEG4 XviD DivX)
By DereX888 in forum User guidesReplies: 16Last Post: 20th Dec 2012, 16:24 -
How to convert mkv to dvd with multi-audio track and multi-subtitles?
By funnybunny in forum MacReplies: 1Last Post: 6th Jul 2011, 15:21 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 13:16 -
Multiple steps to create multi-audio, multi-subtitle DIVX from DVD
By schwarznavy in forum DVD RippingReplies: 8Last Post: 10th Nov 2008, 03:01 -
any good tools MKV -> AVI with multi-track audio support?
By helloguys in forum Video ConversionReplies: 1Last Post: 18th Nov 2007, 12:41
