  1. Hi guys
    Is there any software that will ripp just the ac3 file from a dvd?
    or a ripper that ripps the vobs and have a seperate ac3 file.
    cheers DAZA
  2. SmartRipper will extract the MPEG2 file and the AC3 file from a DVD using Stream Processing/Demux.
  3. Thanks mate
    i did as you said but still cant see a .ac3 file is a .ac3 im looking for?
    i selected enable stream processing and then demux to extra file.
    cheers DAZA
