just copied my first dvd used dvd decrypter then dvdfab and then copy to dvd.everything went well but i play movie on dvd player and when actors talk words are appearing on bottom.just like if i have close caption on but i dont.i would appreciate the help thanks
Sounds like the subtitles got turned on. Use the remote and turn the subtitles off.
It doesn't matter if it didn't copy the subtitle menus or not, they're probably still on there. Just use the "display" button or a facismile on your clicker, move the cursor over, and turn them off.
First off don't use the term copy, use back-up instead. Do you know how to use your remote control?
yea i know how to use my remote,any suggestions.also sorry for using wrong term.
copying
By merc68 in forum DVD RippingReplies: 13Last Post: 7th Nov 2009, 17:26 -
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 21:03 -
Help with copying DVDs. Thanks very much.
By seymoria in forum Newbie / General discussionsReplies: 8Last Post: 22nd Jan 2009, 12:06 -
Copying with Nero8
By Jomapil in forum Newbie / General discussionsReplies: 4Last Post: 4th May 2008, 07:14 -
copying????
By bamf321123 in forum DVD RippingReplies: 1Last Post: 23rd Jun 2007, 06:39
