I just created a basic DVD in DVD Studio Pro with a Main Menu, Scene Select menu and a 6 minute video. I built the project and got a Ausio_TS file and a Video_TS file. I burned them onto a TDK DVD-R disk using Toast Titanium and a Pioneer 105 burner.
When i put the DVD-R into my Mac it plays fine, but it won't play in either of the two Sony stand-alone players I have. Does anyone have an idea of what might be happening or a step I didn't take?
Thanks for your help.
Results 1 to 9 of 9
Did you try to play the VIDEO_TS folder with Apple DVD player before you burned it?
Is this your first project (or just the first one that didn't work)?
I have a G4 with Pioneer 103 and 2 Sony Standalones and have had no problems (though I have never used TDK)
jbcandkcI'm just sitting here watching the wheels go round and round.
-John Lennon -
This is my first project. I actually just tried it in a generic player and it worked fine. What DVD-Rs do you recommend to use with a Sony player?
If you look up your model here: https://www.videohelp.com/dvdplayers
there may be comments from other owners about what media works best.
Nearly 3000 are listed. :c)There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Imation has been my favorite so far.
I have tried Fuji, they burn but will never verify successful in Toast Titanium (but they still play in my standalones though).
I bought a 5 pack of house brand DVD-RW from Fry's branded "Great Quality" that I use for testing and they verify and play great.
So at this point I can only say that I don't buy Fuji anymore.
-John Lennon -
It seems many Sony set-tops do not accept -R. However, they all seem to play +R. Check the compatibility tables.
The older Sony's DO NOT like anything unless it is a factory disc....DVD or even CD. A girlfriend of mine has such a Sony. And it seems that the fancier the older Sony (ie 5.1 digital blah blah blah)...the worse they are(were). Her's wont play my +R's from my Philips 985.
Have you tried burning to a DVD-RW disc and trying it in your Sony stand alone player? If it plays without problem, then try changing the settings of your burning software so that the DVD-R disc is burned as a DVD-ROM disc, which DVD-RWs are burned as. Also, Record Now Max burns DVDs that are comptable on most stand alone players. Hope this helps.
When I put it into any of the Sony players I have, the door of my DVD player keeps opening. I read the compatibility of my player and it seems as though people have had no problems playing TDk DVD-Rs in that particular machine. Could it be the setting I'm burning it at or Toast?
recorded dvd won't play on computer or other players??
By wundahoss in forum Newbie / General discussionsReplies: 6Last Post: 9th Jan 2011, 17:55 -
Burned Video DVD Won't Play in Standalone Players
By adamwolf1965 in forum Newbie / General discussionsReplies: 2Last Post: 1st Jun 2009, 22:21 -
New guy, movies won't play on certain DVD players?
By koreninja in forum DVD RippingReplies: 6Last Post: 12th Oct 2007, 23:53 -
DVD won't play on most dvd players
By green_boots in forum Newbie / General discussionsReplies: 3Last Post: 3rd Sep 2007, 00:12 -
HELP! DVD's won't play on stand alone players
By jessandjeff123 in forum Newbie / General discussionsReplies: 9Last Post: 7th Jun 2007, 07:59
