Just released by Reuters:
Philips Says New Technology Boosts DVD Capacity
AMSTERDAM (Reuters) - Dutch Philips Electronics said on Friday it had developed a new technology with Japan's Mitsubishi Kagaku Media that nearly doubles the storage capacity of data on recordable DVD discs.
Philips, Europe's largest maker of consumer electronics and lighting, said its new dual-layer technology raised the capacity of recordable DVDs (DVD+R) to 8.5 gigabytes from 4.7 gigabytes for single-layer DVD discs.
The company said in a statement users would be able to record four hours of DVD-quality video or 16 hours of VHS-quality video, without the need to turn over the discs.
Philips said it would demonstrate the new technology at the CEATEC Japan 2003 industry show, which will be held from October 7 to 11 in Makuhari, near Tokyo.
Mitsubishi Kagaku Media is a unit of Mitsubishi Chemical Corporation, Japan's largest chemical firm.
This sounds very intresting I wonder if our curent dvd+rw drives will write to these disks. I thought I read somewere that the only thing needed is a firmware and software upgrade (with a phillips dvd+rw drive that is).
unlikely.. if it were that easy then HP would have kept the promise to its customers that is dvd+r drive would be able to write dvd-r with a firmware upgrade (maybe it was the other way around)..
i hope dvd+r9 discs going to be a reality... if so, they win the "war".. unless the dvd-r folks can do the same thing.. it should be interesting.. -
Although the DVD+R9 discs will be compatible with existing DVD players and DVD-ROM drives, none of the current DVD+RW recorders/burners will write to them.Originally Posted by Grant_H
And Philips isn't about to make the same mistake twice by promising that our DVD+RW drives will support writing to the new discs via firmware upgrades. (Btw, the original promise was that the first gen DVD+RW drives would be capable of burning DVD+R disc via firmware upgrade)
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 03:16 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 22:52 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 13:39 -
Help on Dual Layer DVD
By mn072065 in forum DVD RippingReplies: 9Last Post: 16th May 2007, 09:36
