  1. Hi there,
    is there any programme that will demux an avi (divx) file ?
    TMPGEnc demuxes the file but the output is in mpeg format for audio and video. I want the output files (audio & video) to be in the same format as the original video (For example if the original video has an Uncompressed sound, I want the audio file after demuxing to be in the same Uncompressed format too).. Same goes for the video.
    Thx in advance.
  2. Virtual Dub can do this. Click on the "Tools" link to the left or:
    http://www.virtualdub.org
  3. I have VirtualDub, but unfortunately the help file is corrupted and I don't know how to demux with this programme. Can anyone help me out ?
    Thx.
  4. From the faq:
    How do I demultiplex a MPG,AVI,DivX,ASF?
    Demultiplex is when you split the video and audio to separate files.
    For MPG use TMPGEnc, select File->MPEG Tools, select Demultiplex and open the mpg and hit start. Other Demultiplexer is Womble MPEG2VCR, DVMPEG.
    For AVI, DivX,ASF use Virtualdub, first select File->Open Video File to open the video and last select File->Save WAV. If it's a DivX or ASF you maybe want to convert the audio to WAV PCM then select Uncompressed PCM under Audio->Compression and be sure to select Audio->Full Processing before saving.
