So now that I have my DVD file on my hard drive, it's still too big for one DVD-R with the most compression. What are the best ways to split it to two DVD-Rs. I'm sure there isn't one best way, but I'm looking for a few options with perhaps some advantages and disadvantages pointed out - Thanks for being so helpful.![]()
Results 1 to 16 of 16
I thought that was for shrinking to one? It won't fit on one.
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
sometime soon this tool will be available and splitting will be one of it's features
multi purpose DVD stripping tool
just a few more little glitches to overcome and it's gonna be ready, so watch this space
it's never been simpler -
captain,Originally Posted by Captain Satellite
not sure what u used for compression (it doesnt sound like u did that 'yet'), but i used dvd2one and put two of the longest movies that i know of, JFK and braveheart, on one dvd (movie only) and they were both crystal clear perfect =)
shark
I also use DVD2One. I think it is one of the best compresion programs. It takes me about 15 minutes to compress a DVD and the quality is very good. But, in some cases I do have to split up the DVD in order to get the best results. I have tried DVDXCopy, but it did not work. Then I tried DVDFab and it worked. The only problem I see with DVDFab is that the second disc does not have a menu system.
You are right, when it works it is very good. The only problem is that it does not always work.
Thanks for all of the replys, I'll give them all a try and see which I prefer.
Hi all.
thesharkman, would you mind telling us what viewing equipment you used?Originally Posted by thesharkman
I wish I heard (read) that more often.Originally Posted by Captain Satellite
Nice one, Captain Satellite.
[/quote]
ddlooping,
i have a pioneer a4, 1g, pIII - running ME, BeAll dvd-rs and have daewoo 5800 set tops. good luck =)
shark
Hello thesharkman.
You missed the most important part:
What monitor/tv you viewed this double-backup on. :P
DVD's that split?
By videobread in forum MediaReplies: 16Last Post: 7th Dec 2009, 10:49 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 08:58 -
How do i split 7.92GB DVD footage to 2 dvd-r ?
By rockonvidtrade in forum Authoring (DVD)Replies: 4Last Post: 11th Feb 2008, 12:47 -
Please Help-2 Split DVD 5's back together onto DVD 9 w/vob blanker, pgcedit
By ashoun in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2007, 08:34 -
Re-join single DVD-9 film split onto two DVD-Rs
By denti alligator in forum DVD RippingReplies: 11Last Post: 24th May 2007, 21:47
