My dad and me will be taping a wedding with two video cameras and I was wanting to know if there is anyway to create a multi-angle video where if you want to watch one side or the other just switch my selecting the multi-angle button on your remote. Any suggestions would be appreaciated.
You'd need a high-end (ie.: expensive) DVD authoring program for that. Check under TOOLS on the left and go to DVD Author. Thats takes you to lists of software, comments and prices you can check out.
Good luck with your project.There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Does anyone have a step-by-step process on how to create multi-angles? Starting from what type of files you have to create with which software. Please, I am creating a wedding video with two angles. The videos are already on a dvd+RW disc if that helps.
Originally Posted by b_ramsdell
That being said, look for some of this info in my past posts.
The video being already on disc will probably hurt more than help. Why?
You have to capture into the computer each of the 2 angles, and they have to match in length. Then when exporting and encoding, alot of other criteria have to be identical also. Having them be already on disc, without understanding what settings need to be identical pretty much dooms them to uselessness as far as multiangle.
Cheapest (legal) multiangle software that I know of is Pinnacle's DVDImpression Pro (unless you're on a Mac and can get DVDSP 2 upgrade). It does the job, but has some bugs/quirks.
HTH,
Multi-Angle DVDs... and Blu-Ray?
By blazin-j in forum Newbie / General discussionsReplies: 11Last Post: 12th Oct 2010, 11:40 -
How to compress the DVD with multi-angle feature?
By UMO in forum Newbie / General discussionsReplies: 7Last Post: 22nd Mar 2010, 22:14 -
Backup a multi angle DVD
By src2206 in forum DVD RippingReplies: 1Last Post: 9th May 2009, 00:34 -
Multi-Angle DVD-9 to Single-Angle DVD-5 help
By rayden54 in forum DVD RippingReplies: 6Last Post: 11th Sep 2007, 20:44 -
Multi angle - dilemma
By flipzoso in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 02:36
