http://www.mediachance.com/dvdlab/history.html
Version 1.3 BETA 3 (download dvdlabup13beta3.exe (4.2 MB) - you need to have installed at least full 1.1 version)
- New Cardinal Shape objects for menus. Cardinal polynome or line differs from a normal straigth-edge polynome - it can be rounded by seting a Shape Roundness (Tension) which is a great way to create nice smooth shapes.
- Layer effect settings for objects ( Normal, Screen, Multiply, Hard Light, etc..)
-audio in assets now show the total time
- fixed Adobe PSD import with layers (crashing or not importing all layers)
- some internal memory fixes for menu audio and other Compile memory problems
- Transitions in Connection now have much smaller representation which fits between menus (and it also doesn't shift menus outside screen.)
- you can now move First Play and Title buttons in connection. Also a smal facelift on connection object was done.
- you can't move object in connection outside reachable area.
- Multiplexer fix: SCR sequencing negative data fixed
- Flexible muxing renamed to Alternative and a warning is displayed when in use
- fixed Page Curl with the pre-post timer
- Record module, added size indicator,
- Ability to choose and burn Mini-DVD (DVD on CD-R)
- Preparation structure for VMG and multiple VTS in next versions
