First problem: They burn bad discs with CloneDVD/AnyDVD which appears to be a known problem from my searching the forums.
Second problem: I am trying to back up Irreversible (w/Monica Belluci, Mmmmmwith DVD Shrink 3.0 beta 5/Nero 6. All I get is a garbage filled video and audio disc. It plays but everything is corrupted. Im almost sure it is the disc but is there a remote chance it could be something else? Ive backed up successfully before on these discs with Shrink/Nero but this one is giving me a real hard time.
Thanks in advance.
Results 1 to 14 of 14
I had/have a problem with these disks and ULead Moviefactory. It says that the job was succesful but my DVD player says NO DISC.
I do the same job with some 1X cheapos and everything is fine.
Anybody know if these disks have problems??? -
I use Vebatim disks (+R). No problem here. Although my writer is a verbatim. I did have a problem with a bunch of Verbatim +RW disks. Sent them in and they sent out a new batch.
Don't give in to DVD2ONE, that leads to the dark side. -
I've had nothing but good luck with Verbatim, although I _have_ run across a few players that are picky about them. I think they might be having QC issues.
- Gurm -
I only had problem when using copytodvd, after I shifted to imgtool and dvd decrypter, it works fine!
BTW, it's not only vertabim dvd+r, I had same issue with memorex dvd+r -
I have used both Memorex DVD+Rs and Verbatims, which are both by RICOH. Never had any issues. I use a TDK 4X burner, and the latest version of Nero before version 6. I set up Nero to do a DVD-ROM(UDF/ISO) and they play perfectly fine in my Philips player. Philips is one of the major companies behind the DVD+R format, so that may be why they work so good. In fact I have never had any issues with Nero or any of the brands of DVDs I have used(Fuji, Imation, Sony, Memorex, Verbatim), so either I have a very good burner that is not sensitive to badly manufactured DVDs or my DVD player has no problems reading any type of +Rs.
I have burned about 30 of the 4X +R discs (by Ricoh) - no problems whatsoever (except I made two coasters trying out DVDXCOPY Express - after two failures, I uninstalled it) I have since stayed with Shrink and RecordMax or Decrypter. The burned discs will play in my Zenith and Sony standalone players but not my old Toshiba 1200. Also, the Memorex +R 4X (also by Ricoh) works just as well for me.
Verbatim has been switching manufacturers lately. I have some made by MCC and they suck. about 1/2 of them give bad burns. the Ricoh ones work fine.
Are you trying to burn 4x media in a 2.4x burner. When I burned 4x media in my 2.4 burner what I got was a disk that might play wouldn't play well or could not be seen at all depending on the player.
You know, I never checked the manufacturer of these discs. I will do that when I get home.
Oh and I have Phillips player as well -
Verbatim has been switching manufacturers latelyGeronimo
I bought a pack of 15 verbatim 4x DVD-R a long time ago now and all of them were unusable above 4GB. I could visibly see bubbles and voids in the dye near the outer edge of the discs. My solution is to simply stay away from their media.
150 pieces of Verbatim DataLifePlus 2.4xDVD+R [RICOHJPNR00] here.
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
.mvb files... Giving me trouble... Errr
By Ronaldr in forum Software PlayingReplies: 4Last Post: 4th May 2009, 23:56 -
Regular DVD's giving me playback issues, Need some advice
By heman31 in forum DVD RippingReplies: 2Last Post: 29th Oct 2008, 19:35 -
DVD Player is giving me trouble wth DVD-Rs
By Veepa in forum DVD & Blu-ray PlayersReplies: 4Last Post: 27th Nov 2007, 10:31 -
Gui for Dvd Author keeps giving fatal error
By BobT in forum Authoring (DVD)Replies: 23Last Post: 7th Sep 2007, 12:10 -
Converting DVD-audio is giving me a headache (weeej, mission accomplished)
By Bresso in forum AudioReplies: 15Last Post: 12th May 2007, 14:55
