This is driving me NUTS! Here's the problem, and from what I've read, this definitely IS a problem with many people. I'm trying to convert mpeg2 files from PAL to NTSC so that I can author them with DVD Lab to play them on my standalone. The settings from Pal to NTSC conversion in "TMPEG Plus" are what everyone says to do:
Stream type: MPEG-2 Video
Aspect Ratio: 4:3
Frame rate: 29.97 fps
Rate control mode: CBR
Bitrate: 1800 kbs
VBV Buffer size: 0 (automatic)
Video format: NTSC
Profile & Level: Main profile & Main level
Encode mode: Interlace
YUV format: 4:2:0
DC component precision: 8 bits
Motion search precision: Normal
Source aspect ratio: Full screen (keep aspect ratio)
Audio transcode is set to 48,000
MPEG1 - II layer (MP2)
224 kbs
Now, with the above settings, my computer takes about 1 hour, 20 minutes, to convert the PAL mpeg2 file into a NTSC MPEG2 file. At that point, I load the file into DVD Lab, then DVD lab demuxes the file, no problem. It also accepts the settings that the file is at. It reports no errors or incapatable frame sizes, rates, etc. I then author the file and compile it. To test it, I use Power DVD to watch it. THAT'S WHERE THE PROBLEMS BEGIN. When I play the movie,it works. Then when I try to fast forward the movie, it FREEZES. THEN, when I go to the chapter selection that I created for the movie, when I click on chapter 1, the movie plays. When I click on chapters 2 through 6, the movie DOESN'T LOAD. The chapter selection screen just freezes. Then I hit the "title menu" option, and Power DVD goes back to the main screen with no problem. Just for the heck of it, I burned the movie onto a DVD+RW and tried to use it in my standalone. It does the exact same things wrong on my standalone that it does wth Power DVD.
Am I doing something wrong regarding the TMPEG Plus settings"? If so, WHAT? I've tried using 720x480 instead of 352x240. That didn't change anything. I tried a framerate of 23.97 with a 3:2 pulldown, and THAT didn't work. All settings that I tried produced the same results. Any help with this problem would really be appreciated.
Results 1 to 12 of 12
I see one problem
352x240 is VCD which is mpeg1
that might be giving you a problemHope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
DVD = MPEG2 at 352x240, 352x480, 704x480 and 720x480Originally Posted by The village idiot
VCD = MPEG1 at 352x240 at 1150kWant my help? Ask here! (not via PM!)
720 x 480 pixels MPEG2
704 x 480 pixels MPEG2
352 x 480 pixels MPEG2 (Same as the CVD Standard)
352 x 240 pixels MPEG2
352 x 240 pixels MPEG1 (Same as the VCD Standard)
OK Smurf. You win -
From what I understand, it can also be used as a setting for Mpeg 2. Is this not correct? Also, as I stated in my other post, I've also tried 720x480 and got the same results.Originally Posted by The village idiot
I tried that setting already, except for the "do not framerate conversion" part. I'll give that a try, but I've done the 23.976 with the 3:2 pulldown on playback, and that didn't work.Originally Posted by FOO
I only tried DVD-Lab once. It was a project I made with TMPGEnc Plus 2.5 where I used the 2-Pass VBR NTSC DVD template with LPCM audio. The input was NTSC capture and I used an AviSynth script (decomb) to do IVTC so for all intents and purposes I was feeding TMPGEnc a 23.976fps stream so I encoded as non-interlaced with 23.976fps (29.97fps internally) with 3:2 pulldown on playback blah blah blah
I did a rather simple menu (afterall my first time using DVD-Lab) and the sound was ever-so-slightly out-of-sync. So I tried the M2V and LPCM WAV in both SpruceUp and TMPGEnc DVD Author. Guess what? Both had dead on perfect sync.
So I start reading that some people have trouble using WAV audio with DVD-Lab so I converted the LPCM WAV that TMPGEnc Plus 2.5 created to a 224kbps 2.0 AC-3 using the AC-3 encoder that comes with Scenarist.
Once again the DVD-Lab project (now with AC-3 audio) was out-of-sync.
Then some people commented that it could be the way TMPGEnc does pulldown and that maybe it is better to encode at 23.976fps WITHOUT using pulldown and then use that pulldown.exe thing to apply the proper "flags" to the stream.
So my point is DVD-Lab may not like a mpeg-2 TMPGEnc Plus 2.5 encoding that uses the settings that TMPGEnc uses.
I've simply decided to keep using SpruceUP and so far my testing with TMPGEnc DVD Author are going well so I will probably buy/register it when the time comes.
BTW I was using the newest version of DVD-Lab Version 1.3 BETA 3
I gather from all that you suspect DVD lab of having a problem.
I really haven't done enough experiments,
I don't understand at this point how a "good" mpeg2 whether
it's soft pulldown or not , can get outta sync during Author
when it was OK before.
I believe you. I am trying to figure out how they could screw it up
just by multiplexing. -
Well I like to think I know what I'm doing (mostly hehehe) so I'm POSITIVE that I did nothing wrong with the TMPGEnc Plus 2.5 settings to cause havoc.Originally Posted by FOO
It is also suspicious that the same M2V and LPCM WAV files author with perfect sync using 2 other authoring apps and that only DVD-Lab had a problem.
So yeah I'm suggesting the problem is with DVD-Lab and not with TMPGEnc Plus 2.5 or my files.
DVD lab was a very impressive work from day one.
Also from day one there were reports of the low level
operations screwing up.
..acts different depending on what kind of audio was the big one.
.. note that Oscar didn't write all of it. He licensed MPEG
stuff.
I couldn't do it so I can't complain. I wish I could.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
