I am using DVD Shrink and Record Now DX for burning.
After I shrink the DVD I go to Record Now DX and it says that there is no compatible DVD recording device.
I have a Pioneer DVR-106.
but when I open Record Now DX I can select the DVR-106 if I use the wizard.
If I do not use the wizard all it shows on the left hand side of the screen is my regular DVD ROM drive.
Well anyway if I use the wizard I go through all the steps to make a Data Disk and after it is finished burning, I put it in my DVD player and I get a error message saying "No playback feature found".
If anyone knows where I can find info to make sure I have all the settings correct for Record Now DX that would be extremely helpful. Thanks for your time... Later... Phil
Results 1 to 12 of 12
Try copy to dvd. It is probably the easiest burning program to use going around.And so far over 200 burns with no coasters.
Do you get the same problem with nero ?, have you tried a re-install of the program ?
Why would a data disk play in your DVD player? What are you putting on the disk?
Might be that the 106 is pretty new. Or might be some other incompatibility in your system.
And to whoever asked, RecordNow doesn't have a template for Video DVD, you have to pick Data Disc.
- Gurm -
yeah for Record Now DX you have to select Data Disk.
It may be that the 106 is to new because on my dad's system he has a 105 and I never had any problems with it. I just did not know if there was anything different that I had to set up... Thanks for all the help from everyone... -
have you downloaded the latest px engine for record now max ..... you will need it for the 106 to work proper
I'm not sure if there IS a PX Engine update for Record Now DX or not.
Let's check!
Checking... (at the Veritas server, odd!)
"Veritas Update Manager, 882k" INSTALLED...
Checking... (now at the Sonic server)
Nope, up to date.
4.61DX is the latest version.
- Gurm -
Thanks Gurm for checking
I love your Pic to by the way.
Thaks too, to Dougy69
I downloaded Copy To DVD and it works great. Thanks for the help on that.
I am going to check to make sure as well that I have the most up to date version for Recored Now DX, but I am pretty sure that I do. Thanks again for everyones help... -
OK well I was just looking at the compatibility list for Record Now DX and it does not support the DVR-106 burner. No wonder I have had some problems...
If you want to check out the list click below. http://eval.veritas.com/downloads/pro/px358.pdf[/url]
Help with burned DVD's skipping
By BDrums1971 in forum Newbie / General discussionsReplies: 20Last Post: 1st Sep 2013, 15:06 -
i just burned a dvd?
By just in forum Newbie / General discussionsReplies: 1Last Post: 20th Nov 2008, 21:41 -
Problems with burned DVD's
By iceman22 in forum Authoring (DVD)Replies: 4Last Post: 3rd Sep 2008, 19:00 -
Burned DVD's Out of Sync
By RailheaD in forum AudioReplies: 43Last Post: 11th Dec 2007, 10:09 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59
