Hi
I created mpg files using MPEG2CUT. Then using Sonic MyDVD I managed to create the DVD successfully. However, when I play it in a standalone player the sound is lagging about a 1 second behind.
This doesn't happen when I play the DVD through PowerDVD on the PC.
Can someone help me? Thanks
1. Different Media
2. Slower Burning speeds
3. Test it on another player to be sure. -
The old version 1.x of Mpeg2Cut has a lot of compatibility problems.
Try version 2 - Mpg2Cut2 - which resolves a number of issues from Version 1, and adds a number of new features.
Download the latest version of Mpg2Cut2 at
http://www.geocities.com/rocketjet4/
If you are having problems with Version 1,
then give Version 2 a try.
For cutting VOBs, I recommend the following::
- "menu - Output - Preamble - MAXIMUM"
- Also use "PVAStrumento" from Offerynto fix timecodes. -
Audio sync probs aren't created in the burning process. That's just a data transfer and burning process/media has nothing to do with it. If your finished disc has a sync issue, your file was fucked to begin with.
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
Annoying video/audio sync problem
By WebMaximus in forum DVD RippingReplies: 2Last Post: 12th Nov 2011, 08:59 -
Audio video sync problem
By FrankieToh in forum Newbie / General discussionsReplies: 0Last Post: 3rd Dec 2010, 08:53 -
Mencoder - Audio / Video Sync Problem
By krishnareddy in forum Video ConversionReplies: 0Last Post: 22nd Apr 2009, 00:05 -
Audio Video Sync problem
By m baqar in forum Authoring (DVD)Replies: 1Last Post: 27th Mar 2008, 01:59 -
Audio/video sync problem
By Hekey Williams in forum DVD RippingReplies: 1Last Post: 8th Oct 2007, 05:27
