Hello!
I'm using PSP, and need to make a line with a bend in it.
I can make a line okay, I can rezize it and move it etc but I'm struggling to put a bend in it.
Like a 's' shape, you know?
If anyone can help I'd be very grateful but I'll keep trying in the meantime...
....oh, wait, shit, here comes my boss, back to work
Will
Results 1 to 13 of 13
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
I do!!! :cD hehehe
The key is using VECTOR instead of RASTER
From PSPro Help:
"After you have selected the Tool Options palette tabs settings and chosen foreground/stroke and background/fill styles and textures, draw the line. The Bezier type creates a curve. While creating a vector curve, you can use the Drawing tool to rotate, move, and deform the object. You can edit it later using the Vector Properties dialog box and the Vector Object Selection tool. Edit a raster curve as you would any other raster selection."
** when you select the drawing tool - go to its Options Box -> TYPE -> BEZIER CURVE
"To draw a Bezier curve:
1 Position the cursor on the image where you want the curve to begin.
2 Press and hold the left mouse button.
3 Drag the cursor to where you want to end the line, and release the mouse. An outline showing the width of the curve’s line appears as you drag.
4 Create the curve by clicking the mouse away from the line two times and dragging to shape the curve. A node handle appears each time you click. The first click sets the angle and target point from the starting node; the second click sets the angle and target point from the ending node.
· To create a semi-circular curve, click the mouse where you want to position the top of the curve, and then click again to bring the curve from the endpoint up to it.
· To create an "S" shaped curve, click and drag once on one side of the line and once on the other.
5 Release the mouse after editing the ending node to set the curve shape and apply the appropriate style and texture at the selected line width."
or.......................................
Easy, cheating way: :cD
Start a new image
Go to Preset shapes (tool option: "create as vector")
Pick (anything with a curve like... Jupiter) :c)
Plunk it down
You'll see you can drag it to get degree/length of curve
Save it
Reopen it
Erase portions you don't need
For an S - duplicate that and lay one reversed where the original ended.
OR super cheater way :cD
Make a large font "S" (use Create as vector here too)- drag and size to your liking - erase portions as necessary - save as with any drawn graphic.
Take your pick.
:c)There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Man, that's superb, many, many thanks
Far better than the 'draw it freehand' someone once gave me
Thank you my little US/UK cross-bred friend
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Do you like my amended avatar BTW?
I did that in PSP.
Not bad for a, what was it you called me, oh yeah...
...a newbie
W.tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Cross-bred??!! :co ummm I'm not sure you meant that exactly.
What like a Lab/Collie mix? Just what are you saying??
:cD
I hope one of the ways of doing it works out for you. :c)
And yes, I saw and instantly loved your new avatar. Great work!
Now, if you could just be trained to read the Help files....................
.... a girl can dream..............There's no place like 127.0.0.1
Erm, right, okay.Originally Posted by Gees
Maybe that could be your new signature.
:cD Hmmmmm maybe.
You know I am just kidding with you. :c)
I had to get you back for the "cross-bred" comment.
How'd you make out?There's no place like 127.0.0.1
Man, you're sensitive
The cross bred was the US and UK locations, you didn't get it?
First suggestion you gave me was superb, worked first time
I still think it's a great sig, maybe you and Craig Tucker ('try a forum search') could could up with something together
I'm thinking of changinmg my signature to:
"lets shut down the forum and never communicate again"
That's some pretty good work Will. It doesn't look newbieish (is that a word?).
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Thanks, that's nice to hear but trust me, PSP is a breeze.Originally Posted by Conquest10
I know a lot here love (Ulead) Photoshop (I've never tried it), but for me there's no turning back.
I might know only 10% of PSP's full capabilities, but it's 10% more than Photoshop
If you like PSP (I do - it's very intuitive, specially as I've been using it on & off since V 3) you should try GIMP. Less intuitive, yes, but at least as powerful, great filters and it's free. Learned to love it during one of my Linux fits, and luckily found a Windoze port when I came back to the main stream.
Photoshop is heavy overkill for 99.9% of every graphics task I can think of.
/Mats -
Actually, once you get to know your way around PSP, its not that hard to use Photoshop. Its very similar but some things are a little different. I don't know about the latest version but the one I used (I think it was 5 or 6) was very similar. It even outputs and opens Photoshop files.Originally Posted by Will Hay
Photoshop is by Ulead in the UK? Here in the US its by Adobe.His name was MackemX
No, no, it's definetley UleadOriginally Posted by Conquest10
Well done!
What paint program do you use for your computer?
By johns0 in forum PollsReplies: 26Last Post: 25th Nov 2011, 05:02 -
Is It Possible To Create A Custom Color From A Picture, For Text In Paint?
By V Bot in forum ComputerReplies: 10Last Post: 1st May 2011, 23:00 -
Paint Shop Pro - "Sin City" effect?
By stantheman1976 in forum ComputerReplies: 5Last Post: 30th Apr 2009, 16:56 -
FREE Download of Corel Paint Shop Pro X Software
By MJA in forum Off topicReplies: 0Last Post: 13th Apr 2009, 20:55 -
PROBLEM: Animation Shop Won't Export To Paint Shop Pro 8
By Aaron1927 in forum EditingReplies: 1Last Post: 10th Jul 2007, 10:44
