Are there any prorammes in which you may load a divx or mpeg file so as the programme to show you the average bitrate of that specific file ?
Just open the file in media player and choose properties. You can also d/load "MPEG Properties" under the "Tools" link to the left.
http://www.tecoltd.com/bitratev.htm
This is a MPEG bitrate viewer. You have to load a Video stream (m2v, mpv).
If you use CCE, you can use the advanced settings after creating the video information file (.vaf). -
then right click the file and choose properties, the summary tab has the info you want
peace out,
dumwaldo
AWW MA! you know i'm not like other guys. i get nervous and my socks are to loose. -
If you're trying to figure out a DivX file framerate, you could also use VirtualDub, under Video > Frame Rate.
There you also can change it, but then you'll have video/audio desynchronization
DVD Bitrate Viewer for Mac OS X???
By bendermac in forum MacReplies: 8Last Post: 17th Nov 2011, 08:58 -
Simple BD sup viewer??
By cal_tony in forum SubtitleReplies: 3Last Post: 20th Oct 2011, 11:03 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 15:01 -
Looking for FLV bitrate viewer
By kevin3d in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jan 2008, 17:30 -
YUV viewer
By mourya in forum ProgrammingReplies: 0Last Post: 31st Oct 2007, 13:38
