I have 3 mpg files of a movie and now i want to take those three files and put them into one file
How can i do that with TMPGenc if its possible??
Results 1 to 11 of 11
Go to File -> mpeg tools. The rest is pretty obvious. But beware of A/V sync problems. TMPGEnc only promises to handle mpegs it has created itself.
/Mats -
Not much, I'm afraid, xcept trying other apps capable of merging mpegs, or rethinking your strategy and try to get by without joining them. I've tried, believe me, and finally gave up after downloading and trying a whole bunch of mpeg joiners.
/Mats -
I do not think you will get any sync probs following Mats method, post back and let us know.
spent 120 $/€ and buy mpeg2vcr....
There are also some other mpeg 2 editors allowing joining. Search the tools section of this site to read for some... -
Do you need to do this?
If your burning to DVD, there's no need to join them. If you watching on a computer, then make a playlist for all 3 files, and they will play sequentially.
If your making a DivX out of 3 SVCD files, then I could see a need.....but you can still do without.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Video and Audio lenght, never match exactly.
Some programs, like mpeg2vcr, when joins mpegs, re-encode slighty those edges and smooth the result.
TMPGenc simply joins them, without doing any modification! So any "gap" between audio / video makes this noise.
TMPGenc Author because of this reason, "cuts" a bit before and after 2 mpeg clips, so this gap noise doesn't occur. But if the multiplexx between audio / video has delays, the result is lipsynch problems.
That's why I suggest mpeg2vcr for joining mpegs. No gap sounds and gurante no lipsynch probles!
Merging files
By drtbray in forum EditingReplies: 12Last Post: 13th Apr 2012, 16:08 -
Merging different type files
By gabriel01 in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2009, 10:58 -
Merging 2 files before Encoding
By niteghost in forum Newbie / General discussionsReplies: 8Last Post: 23rd Jul 2009, 03:13 -
Merging two .ASS files together
By kinghlg in forum SubtitleReplies: 1Last Post: 11th Mar 2009, 03:01 -
merging of .vob files
By jekkherg in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2008, 21:43
