My newly installed Athlon 2400+ runs at 52 °C at idle
and 65°C when running at 100%
Is this normal? Will my CPU be damaged.
Its using a standard AMD Heatsink&Fan.
:punk:
You should be OK. Its a little high, but not outrageously so. I've seen cooler running rigs, but with a standard cooling system, you are about at par.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
If you've got the room in your case:
http://www.sidewindercomputers.com/thsl2.html
And throw an 80mm ball-bearing fan on top of it. A friend of mine has the 800 and sees far lower temps than the stock HSF (of course). Plus the stock HSF can be a bit noisy, a good 80mm fan would be quieter. -
According to AMD's Technical FAQ, the maximum operating temperature for an Athlon varies from 85 deg. C to 95 deg. C depending on the model, and "normal" operating temperatures are usually 65 deg. C or lower. "Normal" operating temperatures will of course very from system to system depending on case size, air flow, heatsink, etc., etc., but it sounds like you don't have anything to worry about.
Open WIDE for Chunky!!!
how do i enable hot swap on gigabyte ga-p31-s3l support hot swap
By tyson25 in forum ComputerReplies: 9Last Post: 13th Apr 2011, 10:53 -
CPU gets really hot (>100°C !) and computer turns off... Thoughts?
By sincostan45 in forum ComputerReplies: 24Last Post: 17th Aug 2010, 00:45 -
How do you cool down on a hot summer day?
By johns0 in forum PollsReplies: 20Last Post: 23rd Jul 2010, 09:37 -
Hot shoe pinout
By danno78 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 31st Mar 2009, 12:19 -
WOW its gettin hot
By Heywould3 in forum ComputerReplies: 14Last Post: 6th Nov 2007, 19:10
