  1. Let's say I get an external hard drive. Maybe 250 GB and I store all my files like music and vids.
    In case I ever want to reformat my computer. Can I just yank the USB of the hard drive off my comp. Reformat and stick it back in and have ALL my files? I will be reformatting the internal hard drive with the windows OS.
  2. Member twodogs's Avatar
    Dec 2002
    Australia
    correct.
  3. Are you serious...
    I have 2 computers and a lot of info on one of them... I would transfer all my files around 60 gb from one to the other through the networks... reformat... transfer back.
    This is so much better.
  4. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    I prefer firewire, but the same concept. Works great, just a little slower than an internal drive.
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
  5. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Even if it were an internal hard drive you can select which drive(s) to format. Say you had two internal you'd be able to format the one with the OS in it and leave the other one untouched. This even works with seperate partitions of a single hard drive. A lot of us use external hard drives for backups and drive images so we can revert back to say the OS and all the basic apps we use. I echo the FireWire statement, the FireWire drives out there now are pretty quick. They can even be powered via the FireWire cable if you've got a Mac.
    Oct 2003
    Texas
    I'd suggest use the main partition (C drive) for system files. Use the external backup for personal files. If you delete/format C: your files won't be affected
