Hello,
I have looked at similar posts but none seem to be asking the same thing as i am asking.
Here is what i want to do, i'll give a rough example later. I want to be able to create a vcd/svcd and have a menu that will have thumbnails of the whats on the svcd. I am not looking for these thumbnails to be animated or to have chapters for the eps. What i would like to be able to do is to select part of an episode (like the opening credits) and use that as the background menu.
For example. A few months ago I downloaded a few buffy svcd's off the newsgroups. Each cd had a menu that had two items to select. One being the main episode and the other being next weeks promo. Up to this point I can do with nero without a problem. What i liked about the svcd's was once you put it in, the main menu used the opening credits of the show as an video or animated background instead of a still image. I opened the image file to see if they included the opening credits seperatly but they did not, they didn't even supply a promo, just one video file, so it looks like both the video menu and promo was both clips of the main video and the main video played without the promo at the end.
Thanks In Advanced for any help.
Ryan Shaffer
rgs80074@cfl.rr.com
You won't find your answer by reading posts. Read the how to guides to the left. And by all means unless you have alot of time to learn then keep your projects simple.
give Nero Vision another try. they just issued an update v2.0.1.9.
http://www.nero.com/en/nero-up.phpI said I'll be done in a minute. I meant a Microsoft minute. -
Not to difficult. This is what you want. An animated background or still in your main menu Am I right? Here go...
Load your avi (I assume it is a divx avi file) in virtualdub
Scroll to whichever part you want. Mark it and save as new avi(Do you want sound or no sound?)
If you want still do a video capture of the picture with BSplayer or Liquid Audio or any player that has a capture button.Then mux your still with a wav file in TMPG
Next encode to svcd with tmpg and finally authored with DVD workshop
with all the whistles and bells.
Forget about Nero
Rotating Video in Menu
By Psymon007 in forum Newbie / General discussionsReplies: 7Last Post: 13th Jun 2009, 00:33 -
looping video for menu
By scoooter1 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 23rd May 2009, 07:03 -
Menu button just starts video over
By Qun Mang in forum Authoring (DVD)Replies: 7Last Post: 13th Sep 2008, 16:06 -
Is it possible to extract the video from a motion menu?
By mjvgiese in forum DVD RippingReplies: 2Last Post: 3rd Dec 2007, 21:31 -
After creating a video CD I only get the menu to appear...help
By dave4500 in forum Newbie / General discussionsReplies: 4Last Post: 25th Jun 2007, 01:23
