Is it possible to convert VOB files into another, more compact format? I ripped the video right from the DVD, but after the fact I realized it was quite big. It's about 7GB and I'd like to get it down to 1/2, or maybe even 1/4 of that size. Any programs that would do this?
Which guide are you following ?
lots of programs can do this
what do you want to end up with ?
a DVD , VCD , SVCD or a AVI or MPG file for editing or something else -
I'd just like it to be a smaller file. I don't neccessarily want to be able to burn it to DVD / CD later. So whatever format keeps it small, but with good/great quality. MPEG-4 ? AVI ? I'm not sure which format is good. So I guess I need a way to convert it to one of those two.
I'd say avi...look at the guides on the left to figure out how.
Not avi, sounds like you want to encode to one of the many MPEG4 codecs (eg. divx, xvid, asf, etc). Many of the MPEG4 codecs have the *.avi extension but are not avi's (MS standard uncompressed video). Anyway, if you're a total newbie you might want to take a look at Gordian Knot:
http://www.doom9.org
You can d/load the software package and find guides for it there as well as it's own discussion group. Reducing the resolution to 520x390 or so at 500kbit/s produces pretty good quaility back ups often < 700 MB.
VOB conversion help
By MarkL1986 in forum Video ConversionReplies: 4Last Post: 14th Feb 2011, 10:10 -
VOB(DVD) conversion Need Help Please
By tonkatoy42 in forum Video ConversionReplies: 1Last Post: 14th Jan 2011, 22:47 -
VOB to DV conversion
By candy56 in forum ffmpegX general discussionReplies: 12Last Post: 29th Dec 2009, 00:53 -
.vob Editing/Conversion
By matedog in forum Video ConversionReplies: 2Last Post: 13th Dec 2009, 12:27 -
Vro to Vob conversion?
By marty mcfly in forum Video ConversionReplies: 6Last Post: 30th Oct 2008, 22:16
