does anyone know why a dvd + rw may become unusable.....i was all set up to burn and i clicked on burn and it started but then an error came up that said the disc may be unusable (i think it was error 1510:3:0).....i erased the entire disc so i don't see why it would be unusable at this point
Results 1 to 13 of 13
I have had a similiar instance happen to me when I used different programs to burn and then erase the disc.... ie, Nero to burn and Record Now max to erase, and vice versa. I am not sure why this is but my DVD-RW discs afterwards were unusable. Not that this advice helps you any
but just to let you know how it happens. Maybe you used the same program to burn and erase and then burn again to the disc...in that case...I am not certain.
DVD RWs are more susceptable to scratches, fingerprints etc. Try cleaning the disk. I use Disk Doctor.
thanks......is disk doctor something i buy or download or what?~because i am unfamilar with it......by the way, the program i'm using is DVD Complete....and i did erase and try burning in that program and it wouldn't burn~thanks for the help
Disk Doctor is a device you buy (Media Play, Target?). It resurfaces the DVD. I have used it on several DVD RW's that were unusable and it fixed them.
I think it costs around $25.00. If you want to save money do a search for toothpaste and see what people have to say about using that to clean the disk. The goal is to actually resurface the disk by applying a light abrasive. Then buff it with a lint free cloth to restore the shine.
thanks a lot......so does anyone have other suggestions on how to clean my disk to make is usable??
i need suggestions about using toothpaste to clean my dvd+rw because i am considering doing that~help please!
can anyone help???~please!!~i want to get started on cleaning it but i am unsure if i should use toothpaste or not
Reenie,
Put the word "toothpaste" in the search box at the top of the page. Set it to search all forums. You will find several discussions.
DVD Fab - DVD Shrink - DVD Decrypter OK, and disc is unusable?
By dledm in forum DVD RippingReplies: 7Last Post: 1st Jun 2010, 15:54 -
Windows 7 Upgrade Makes Some PCs Unusable
By deadrats in forum ComputerReplies: 88Last Post: 5th Dec 2009, 05:14 -
Orbit downloader - faded commands unusable
By chis@ in forum Video Streaming DownloadingReplies: 2Last Post: 29th Jun 2009, 02:58 -
Unusable results from VHS to Digital Conversion (Long)
By ZARTT in forum Newbie / General discussionsReplies: 11Last Post: 4th Feb 2009, 02:16 -
Burned an MPEG2, replicator says it's MPEG1 and unusable?
By First1 in forum Authoring (DVD)Replies: 4Last Post: 11th Nov 2007, 14:55
