Can someone suggest a AVI splitter that supports
Canopus captured AVI files.
All the splitter programs in the Tools section dont support my
canopusAVI....
and yes... I have installed the DSVD codec... still dont work...
I just wanna split it exactly in half..
ie: 50 gig to 2 equal 25 gig files.........
HELP!!
Take it from the Champs,
Graffiti is for Chumps!!! -
Hi,
This is probably one of two problems:
Possibility 1: You've got a Type-1 DV file and your various bits of software don't like it. You should be able to find a utility to convert it to a Type-2 DV file which is more windows friendly. I think Canopus do one of these on their website.
Possibility 2: You haven't installed the correct DV codec. Maybe you've installed the free Canopus DV codec from their website. This only decodes AVI files with a FourCC code of "CDVC". If you use a different codec like Mainconcept or Panasonic, they decode "DVSD".
Choice of DV codec can be important because results can vary so much. Personally, I don't like Mainconcept's DV codec because it tries to sharpen the image and ends up introducing noise. I prefer the Canopus one instead. Here are a couple of good reads about DV codecs from doom9:
DV decoder differences
A small study of DV Codecs
As for splitting software, I recommend using Virtualdub in "Direct Stream Copy" mode.
I really hope this is useful to you.
Good luck.
Ian. -
thanks dude.. very helpfull!!
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
Philips DVP5992 plays AVIs, Divx too large
By strommsarnac in forum DVD & Blu-ray PlayersReplies: 3Last Post: 10th Dec 2008, 23:32 -
Large AVI to smaller AVIs
By longlostname in forum Newbie / General discussionsReplies: 4Last Post: 4th Mar 2008, 17:04 -
TubeStick and splitting large mpegs
By benblack in forum MacReplies: 7Last Post: 30th Sep 2007, 15:11 -
How to use Canopus VideoFx with Canopus let's edit2
By perfection in forum EditingReplies: 1Last Post: 25th Sep 2007, 04:56
