By default where does Virtualdub save the output fileEverytime I work with a file I can't find the output file anywhere. I know it doesn't
overwrite the input file because after i'm done I play the original file and i'ts still the same. Am I doing something wrong. How can I configure where Virtualdub places the output file. Please help. Thanx in advance.
I don't think Virtualdub has a default. Its controlled by Windows. So, it probably was in the last folder you accessed through the open/save command. Thus most likly the same folder as your source.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
Cannot find DV output pin
By RalphW in forum Capturing and VCRReplies: 11Last Post: 23rd Jan 2024, 16:14 -
Output file is way bigger than input file in Virtualdub
By sasuweh in forum Video ConversionReplies: 31Last Post: 10th Oct 2013, 18:25 -
Virtualdub output
By DuBsTaR in forum Newbie / General discussionsReplies: 1Last Post: 7th Dec 2011, 13:53 -
i cant find a way to output sound from my tv
By wapfuture in forum AudioReplies: 3Last Post: 26th Mar 2010, 12:49 -
Making XVID videos with VirtualDub: output files w/huge file sizes (~1GB+)
By maskingtape in forum Newbie / General discussionsReplies: 11Last Post: 5th Mar 2010, 00:50
