How do you extract just the subtitles from a dvd? I use DVD2SVCD to back up my region 3 dvd movies. I've used the guide on how to put a dvd movie on 1 cdr. That method works fine with movies that don't have subtitles. Any suggestions and advice will be greatly appreciated. Thanks in advance!![]()
DVD2SVCD can extract the subtitles and put them on your svcd ... its on one of the tabs there ... if you check it off and also check "keep files" you will also have the subtitles in a sep. file ...
also to just extract the subs -- there is heaps of guides and tools on the left for that .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
...or use subrip. I always use SR to rip subs to .ssa format, then use this with VirtualDub or AviSynth (or ffdshow).
/Mats -
Thanks for the replies.....Yes I know DVD2SVCD does subtitles....Is there a guide to using subrip to virtualdub or avisynth? I am trying to convert a region 3 movie to vcd using the fitting a movie on 1 cdr. The region 3 movies have english subtitles....If I use dvd2svcd I don't think I can make it fit on 1 cdr.....I have a TMPGE template that I created called "ONE DISC VCD" by following one of the guides on this site....For movies that don't have subtitles I have fit one movie on 1 cdr by using DVD DECRYPTER, DVDAVI, TMPGE & VCD EASY to burn.
Is there a guide to help me accomplish what I want? Thanks in advance!
Here's a guide, using VirtualDub and TMPGEnc:
https://www.videohelp.com/srtsubsvirtual.htm
/Mats
How to extract/edit subtitles from DVD
By pincrete in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2011, 12:19 -
DVD to MPEG2, extract mult audio tracks, subtitles for replay in WD TV Live
By Jacoman in forum DVD RippingReplies: 5Last Post: 16th Mar 2010, 10:40 -
How to most easilly extract subtitles from DVD ISO
By glompe in forum SubtitleReplies: 1Last Post: 9th Dec 2009, 13:44 -
Can't extract DVD subtitles
By idrougge in forum ffmpegX general discussionReplies: 1Last Post: 21st Nov 2008, 14:58 -
question about how to extract subtitles from dvd
By jimdagys in forum SubtitleReplies: 9Last Post: 1st Nov 2007, 06:10
