  1. forkies
    Guest
    I have a bunch of PAL avi (framerate is 25) that I'd like to convert to NTSC VCDs. How can I do this with ffmpeg?
  2. First, which is the reason you're willing to convert PAL to NTSC? As many DVD players today are able to play both modes.
  3. Guest
    I am aware of that fact.
  4. In that case, to convert to another framerate, just enter that framerate or select the appropriate target PAL/NTSC format in the Quick Presets. However be prepared to image quality loss (as you will be dropping or duplicating frames) and possible sound sync problems.
