I have an ASUS 8200 Deluxe GeForce3 and have installed the HuffyUV codec and am using VirtualDub 1.4.7 and there are NO codecs at all showing up in the compression window to select from. I have tried selecting 24 bit and UYVY in the image format window under video format but still no codecs are showing up. Any suggestions as to what I am doing wrong would greatly appreciated!!
Thanks..
Rick
I found the problem guys...I hadn't installed the Windows WDM driver. After the WDM install and I switched from the ASUS driver to the WDM driver the Huffy codec showed up like it supposed to...Still learning here...
thanks for all the great info you guys supply here...
Video Not Showing In View Window Box (Sound Only)
By Teac23 in forum EditingReplies: 4Last Post: 6th Sep 2010, 11:43 -
problem with compression using virtual dub
By jpez1 in forum Video ConversionReplies: 4Last Post: 3rd Aug 2010, 13:24 -
ffdshow codec not showing up in Virtual Dub
By uglijimus in forum Video ConversionReplies: 2Last Post: 8th Mar 2010, 15:12 -
no options in audio compression for virtual dub
By jonbaker in forum AudioReplies: 9Last Post: 14th Feb 2010, 19:00 -
Window Media Encoder Can't find codecs
By Ensign in forum Video ConversionReplies: 2Last Post: 18th Jul 2008, 11:33
