Ok Im confused... I have been reading on here that changing your sample rate to 44khz will make you fit alot more video on a dvd, but if I make my mpg 44khz the dvd has no audio on it. when I go back to 48khz everything is good. what am I missing here?
Results 1 to 11 of 11
sup dawg
the standard for dvd's is 44.8 sample rates
44.1 sample rates will either cause audio sync and/or no audio at all. -
ight thanks man. did u mean 48 is dvd? anyway.... so whats all this talk about lowering the audio to get more video?
The only supported sample rate for audio in the DVD standard is 48kHz. The only way changing your audio could have an effect on video is if you lowered your audio bitrate, thus allowing you to raise your video bitrate. But lowering the sampling frequency is not going to affect the size, and its not supported anyway. Just use 48kHz, there is no reason to use anything else when making a DVD.
and/or going with ac3 vs pcm, right?
or mp2 if in Pal Land. :c)There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
Those of us who are big audiophiles or audio professionals might disagree and say there still can be some reason for using the 96kHz sample rate. But that's gonna be contrary to the usual reasons for modifying the sample rate (higher quality vs. more compression/smaller space). I know it isn't used much at all, but don't count it out completely. With good A/B comparisons, the difference does become more noticeable.Originally Posted by adam
p.s. try mono if you don't mind it and want to save some space -
I thought The DVD spec calls for up to 192 Kbp - not that you would need to go that high.
Audio details of DVD-Video:
http://www.dvddemystified.com/dvdfaq.html#3.6.2 -
Max audio sampling rate in DVD-Video spec:Originally Posted by videopoo
96kHz using PCM, 48kHz using everything else
Max in DVD-Audio spec:
192kHz w/2ch, 96kHz with 4 or more channels, IIRC. This is independently configurable in authoring/encoding stage.
Join .avi files, different video sample rates
By -mm- in forum EditingReplies: 22Last Post: 12th Oct 2014, 07:46 -
Premiere and sample rates
By tpapictures in forum EditingReplies: 6Last Post: 4th Apr 2011, 21:05 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 11:26 -
DVD --> x264 MKV - I think I'm having an interlacing problem? (Sample Vo
By mob in forum DVD RippingReplies: 13Last Post: 14th Apr 2008, 21:43 -
DVD Audio To .wav Sample Rate Question
By xtreme469 in forum AudioReplies: 3Last Post: 29th Sep 2007, 10:04
