I am a complete noob so please bear with me.
I want to back up my movies and episodic discs.It doesn't matter if I have to use 1 or 2 dvdr's for a complete backup.I was going to get DVD X COPY Platinum but I am hearing it is buggy.So which should I get and why?
1.DVD X COPY
2.DVDX COPY GOLD
3.DVD X COPY EXPRESS
4.DVD X COPY PLATINUM
Oh and which update should I download for the version you think is best?Thanks.
Or do you think I should use some of the freebies from this site?Remember I am new so some of this burning stuff is bewildering.Thanks.
I would suggest always try freeware, or trialware first. Once you have a program that does what you need, then go ahead and pay for it. That was the idea behind them anyway. I also suggest DVD Shrink or DVDDecryptor.
Hello. -
Hi all.
emperor5, before you go and spend your hard-earned cash I'd also suggest you try DVD Shrink v3.0 beta 5.
Why pay for a software when you can get a better one for free?
The only thing you'll be missing is a burning software, but if you burn to DVD-R(W), you could also use burnatonce, another free and great proggy.
If you want to familiarize yourself with both these softwares:
http://www.dvdshrink.info/guides.php
(I'd suggest you also view the v2.3 guides even though I'd advise you to use v3.0 beta 5)
accounting software for Mac bookkeeping software for Mac
By Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 13:43 -
Why does this movie playing software not work? (Bluray software)
By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 03:18 -
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 19:26 -
Developing software that uses opensource or GLP software
By wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 08:07 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 21:45
