  1. fission
    Guest
    hi...
    my old way to copy my dvds doesn't work with the pre release panther builds (dvd2oneX and dvdbackup) and i was wondering if it was possible to use ffmpegx to accomplish some of the task of copying...
    will ffmpeg help?
    -fission
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    ahhh the perils of running beta os's
    did you try OSeX?
