Is it just my DVD-RW burner or does all DVD-RW burners not capable of erasing CD-RWs? mind just doesn't erase CD-RW or is this a software problem? I'm using Pioneer A05, and Nero5.5.
I've had RW disks that won't erase if overburned. You didn't format it for packet writing did you?
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Hi,
Had a problem with a DVD-RW once. None of the 'standard' burning progs would work; Nero, Record Now, Roxio etc. In the end DVDinfo worked perfectly.
http://www.dvdinfopro.com/index.php
Not sure if it will do CDs though.
Mark -
I had the same problem with my sony drive, it would not write or erase. It was a Memorex Platinum CD-RW. It gets stuck on the lead in, until it finally gives up. I've reported in another thread that I thought the dru laser was at fault, but I was dismissed and admonished. Anyway, I submit again that this drive has problems, no matter what the die hards say. For DVD-R burning, no complaints as I've only used the name brand media.
Here's how I fixed it. Used my laptop cd-rw to do the first write to the disk and problems all went away. Once brought back to the dru for a re-write, surprise, same disk BUT this time it worked. Also note, even Sony brand CD-R, gave me skips in my burned cds when burned at max speed. Once reduced the speed, it was much better, 8x. -
Expand on that -- Does NERO give you an error message, does it go through the process, but the disc is still not erased? Does it not do anything? What brand of media? If Memorex, throw the disc out now and cut your losses -- Memorex is 100% garbage imo. What version of firmware?mind just doesn't erase CD-RW
I too have an A05 v1.33 and use NERO 5.5 with DVD-RW mostly, and the odd CD-RW (TDK and Verbatim are all I use for CD-RW), and have never had a problem with either.
Is it possible to erase a DVD+R?
By Han Solo1 in forum Newbie / General discussionsReplies: 5Last Post: 18th Aug 2010, 14:54 -
How to erase a DVD-R disk
By bryankendall in forum ComputerReplies: 5Last Post: 24th Dec 2009, 14:16 -
DVD RW wno't erase
By jollyjohn in forum Newbie / General discussionsReplies: 5Last Post: 20th May 2009, 11:32 -
Can't erase my DVD-RW disc
By hurtstotalktoyou in forum DVD & Blu-ray WritersReplies: 4Last Post: 15th Nov 2007, 10:40 -
HELP - Can`t erase 10 dvd rw discs
By LOWTECH in forum DVD RippingReplies: 6Last Post: 13th Aug 2007, 15:28
