I'm looking for this file. If you have it, PM me.
If you post a link, be sure it actually works.
Thanks.
Nevermind.
I was having issues with my TBC-1000 using the composite, but switching to an all-s-video connection fixed it.
Wierd how that works. Last time I had issues, switching AWAY from s-video made the overly bright image go back to normal.
I used Stinky's tool, which I believe is different from DisableATIMacrovisionDetection.zip, but it is ineffective on the new MMC 8.x series.Want my help? Ask here! (not via PM!)
Not sure if it works or anything, but anything for Lord Smurf...
If needed I also can email the file to you.
http://www.digital-digest.com/dvd/articles/macrovision_graphics.html -
Last time I looked , all Stinky's did was diddle the ATI registry entries.
I wish I could find something to disable the ATI AGC settings and
set it to fixed gain
And I have the hack for MV detection and It works on MMC8.5
Windows 7 does not see my Zip Drive
By kimco52 in forum ComputerReplies: 16Last Post: 22nd May 2010, 21:16 -
.ISO zip file
By nodollas in forum DVD RippingReplies: 5Last Post: 10th Feb 2010, 18:07 -
.Exe vs .Zip Programs
By gonwk in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2009, 04:30 -
What is your most used zip compression utility?
By yoda313 in forum PollsReplies: 39Last Post: 30th Jun 2009, 17:00 -
Can't unzip ffmpegXbinaries20060307.zip
By cerebusthe2nd in forum ffmpegX general discussionReplies: 4Last Post: 9th Dec 2007, 09:39
