Hi, I I think I know what the problem is but I don't know exactly where the solution is located.
For some reason, I can't seem to find any audio/language in any of my media player. I trying to play vcd/svcd, and in the vcd, there are two 3 audio/langauage tracks. But I'm only seeing one in wmp or any other players for that matter. So I'm hearing 2 languages in the movie and it's bugging me that I can't swtich from one audio channel to the next.
The problem is located in the registry file, I think, but I don't know what file it is.
If I'm wrong or if someone knows a solution to this, please post.
all input is appreciated.
Windows Media player does not support multiple audio tracks. They play the first one. Use a DVD software player to allow fully selectable audio tracks. I don't know if the newest version of Media Player supports mutliple auido tracks. If your set on using it, try version 9.
Impossible to see the future is. The Dark Side clouds everything...
Changing the language designation of subtitle & audio tracks
By DeathStalker77 in forum SubtitleReplies: 6Last Post: 8th Aug 2010, 23:32 -
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 18:34 -
Can do BDRebuilder a mkv file with more than one language tracks
By videoten in forum Blu-ray RippingReplies: 4Last Post: 4th Jun 2010, 15:39 -
custom mapping audio channels from different tracks
By Driber in forum AudioReplies: 4Last Post: 10th Feb 2010, 16:51 -
multiple language tracks in iTunes
By Patrick_H in forum DVD RippingReplies: 0Last Post: 15th Feb 2008, 12:12
