ok i got a problem..
when i play a movie with the vobsub, everything is synchronized in the media player, but when i try to make them permanent with this method:
https://www.videohelp.com/srtsubsvirtual.htm
and i put the virtualdub, with this configuration: in video "full processing mode" and i enter in framerate: and choose "change so video and audio durations match", and in audio menu, i put "direct stream copy".
Because if i choose another configuration, the audio will not be synchronized, don't know why?![]()
ok the problem is that the final result is: the audio/video is synchronized but the subtitles play too late....
what can i do? do i need a special codec?![]()
my PC is
Pentium 4
1.80 Ghz
352 MB RAM
32 MB VIDEO
30.00 GB HDD
and if i try to use this other method to put permanent subtitle:
https://www.videohelp.com/forum/userguides/153058.php
when i open the tmpgenc and add the movie, and try to encode it, the subtitle can't be seen, neither the subvob icon activates.
DO i need a special codec? where can i download it?
Im having probs witht the step in this guide: https://www.videohelp.com/srtsubsvirtual.htm
about converting SRT -->SSA, the SRT to SSA converter says "Input File Error, Subtitle 1", ad the SSA is a dummy file 1K
PLZ help, and the one above!! -
OK I presume your sub is vobsub and also you know how to load your sub in virtualdub. Played the file with virtualdub and if they are in synced, don't changed any settings, use the default. Stop playing with framerate etc... Then frameseve to TMPG and encoded a small section for testing
MiniDV Pixilated. Is is too late?
By sj022698 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 23Last Post: 23rd Nov 2012, 05:56 -
sound late from video
By nazim in forum Newbie / General discussionsReplies: 9Last Post: 26th Jun 2011, 14:23 -
Subtitles are 5 seconds late
By h4mza in forum SubtitleReplies: 6Last Post: 17th Nov 2010, 08:22 -
what to do with late bf's unfinalised dvr's
By sunflowerturbine in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 10th Nov 2009, 05:32 -
Subitls 5 seconds to late
By Soixante in forum SubtitleReplies: 5Last Post: 1st Aug 2007, 15:09
