  1. Ok Ive recentlly got into burning stuff to dvd-r,,making compilations etc,
    well ive got these like 10 files,all of the same show,,
    an the way Ive been encoding em to mpeg is ,
    go thru Vdub, then to tmpge,
    then all's good!
    except for these 3 files,, on those when i try an run it thru Vdub,
    I get a
    ''No audio decompressor found to decompress ''
    ,So I went on an tryed to run it thru TMpge, cause sometimes ya dont even need vdub,,
    so I tryed it with tmpge, an the audio part wouldnt load,,
    and I get a
    '' such an such file.avi can not open or is unsupported''
    Does this sound like something anyone has else has had porbs with?
    or anyadvice?
    Or are there any certin settings i should try?
    cause Im ready to put this set to dvd-r but these 3 files goof it all up!
    thanks!
    Bare with me please,,brain cellz not functioning at normal capacity!!
    Apr 2002
    The State of Frustration
    Try using Virtual Dub mod.
    Hello.
  3. whats the difference between Virtdub an Virtualdub mod ?
    Are there any certin setting I need 2 use with VDmod?
    the way I was showed to use plain vdub, was video-direct stream copy
    audio-full processing mode,
    I know theres other ways,but this way seems to do it for me,
    cause im not that knowlegeable with vdub,,
    an now I gotta learn vdub mod!
    thanks
    Apr 2002
    the mod version has been modified to accept AC3 AVIs.
    Hello.
