i have just uploaded 10 mintutes of video using DVIO, however the output file size is 935mb....this is terribly big in my eyes. Is there any other software that can use to get this video, keep the same quality as DVIO does but have the file size a lot lot smaller?
Results 1 to 10 of 10
First of all, what is the file extension in question.
(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
That actually seems small to me, DV is about 13Gb/hour so 10 mins should be over 2Gigs!!??!!
An no, You can't make it smaller and keep the quality. The only way to make it smaller is to encode on the fly to a more compressed format. This will lose quality, but Windows Movie Maker can do this if you want and MS wmv format. -
Originally Posted by Doggiedaddy
You don't say what exactly you are "uploading". The last time I captured some video from a VHS tape onto my hard drive, the resulting AVI file took over 5 Gigabytes of space for about 48 minutes of VHS video.
So your 935 MB for 10 minutes seems about right for that.
When you encode it for DVD or VCD for burning, the resulting file size will be a lot smaller. My 5 GB went down to about 2 GB after encoding.
If you don't have the drive space to handle files of this size, you should get a bigger hard drive. -
Originally Posted by bugster
That's a normal file size for a capture. After you compress/encode it, it will be smaller. How small depends on what codec/format you choose, as well as the resolution.
You can't quote a WMV file size without knowing the resolution and framerate and quality level desired. WMV isn't any smaller than DivX/XviD/RM for the same resolution/quality settings (they are all MPEG4 variants).To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Originally Posted by keith123
WMM is transferring and the encoding it into a lower quality format, that's your problem.
Transfer the footage and then choose an output format carefully to keep the quality."Art is making something out of nothing and selling it." - Frank Zappa
Cant upload video to youtube
By Florida in forum Newbie / General discussionsReplies: 5Last Post: 17th Mar 2011, 00:33 -
Upload test
By Midzuki in forum TestReplies: 11Last Post: 29th Jan 2011, 14:48 -
How do I upload screenshots ?
By jimmalenko in forum Newbie / General discussionsReplies: 18Last Post: 9th Jan 2010, 18:16 -
How to record TV and upload on youtube
By magic_impuls in forum Capturing and VCRReplies: 3Last Post: 25th Mar 2009, 21:46 -
yet another image upload test
By vhelp in forum TestReplies: 0Last Post: 7th Feb 2009, 20:49
