Further to my previous post
https://www.videohelp.com/forum/viewtopic.php?t=175291&highlight=
I am still on the same PSU but have recently installed a USB keyboard in place of an old PS2 one and am now back to regular freezing. The PC completely freezes - only the mighty restart button resolves this. I still have the two side fans off but i am back to the same problem.
It can happen at anytime, during encoding, playing Urban Terror, surfing the web or during login to win2k - anytime. I have just arrived back from work to discover it had frozen 98% into a TMPGenc enc - been on for about 2 hrs.
I am right now gonna purchase a new PSU but I am still at a complete loss as to explain these random system lockups.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
I didn't read the other post, but you might have a cooked processor. Once they cook, there is no fix. Keep track of the cpu temperatures and see if this is the problem. If it bails everytime it hits a certain temp, you need to replace the cpu. This could be caused by a heatsink that is not making a good contact with the cpu. Could be other things too, but it sounds like it only happens when your cpu is working hard. Other thing to check is your memory, though normally memory problems give you a crash not a lock-up.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
8) try running with some of your gadgets taken out or not powered up. EG creative soundcards can be a bit twitchy. Do a big long test and then move onto the next component. ALso 1gb of ram, could be one of these sticks playing up. Throttle everything back cpu speed, ram timings less aggressive. IF worse comes to worse (real bad) re-install windows it might be some sort of software driver clash. Scandisk your disk they fail or have bad sectors. uninstall some software you dont use. defrag .
Run with case sides off.
One way for your compter to freeze is to run it too hot!
could be a FRIDGE on the same power circuit or your sister turning on some electrical gadget (power spikes)Corned beef is now made to a higher standard than at any time in history.
i bet memory .. but who knows ... some systems are just fubared ...
motherboard and all"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Lots of "Freezes" yesterday - often at boot up, the W2k login box appears and then the PC locks. Restart. Attempted some long (2hr) encodes yesterday - PC locks randomly at various points during encoding. Restart. I must have hit the restart switch at least 10 times that morning
This morning my new 420w PSU arrived. I took this opportunity to strip the machine, ensure everything was secured, clean and put it all back together with the new PSU.
Not one lock up since
TMPGenc has been encoding for 2hrs 8mins as I type and its looking good. Fingers crossed
First:
+ Update firmware for your motherboard
+ Update your drivers
+ Check the temp of your CPU. There a re a few tools available out there
+ Check you memory. You can use either the complete test memory from BIOS
+ Check your HD for errors
Last resort: Reinstall windows.
I'm not sure the PSU is the problem, but who knows. -
Originally Posted by jgandara
latest drivers, cpu temp is fine and I've run test after test on memory and HD.
The only thing I noticed when rebuilding the PC was the fan on the graphics card doesn't spinI will be looking into this asap.
other than that the machine is runnning fine at the moment with no sign of those pesky lockups
Frozen Memorex mvdr2102 DVD recorder
By flanmann in forum DVD & Blu-ray RecordersReplies: 1Last Post: 2nd Jul 2010, 04:40 -
Last few minutes of video frozen...
By JohnC1726 in forum RestorationReplies: 3Last Post: 14th Jan 2010, 08:56 -
Frozen frame when going from.mov to .flv?
By beanguy in forum EditingReplies: 1Last Post: 10th May 2009, 11:27 -
Philips DVDR 3350H - Frozen
By zukie23 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 5th Dec 2007, 00:35 -
usb2 mouse keeps frozen up after no using it over night
By deejay.2001 in forum ComputerReplies: 2Last Post: 13th Aug 2007, 17:42
