  1. I use vob2wav (to extract the wav file)-->ssrc (to downsample from 48 to 44.1) -->toolame (to encode to 224 bitrate) for my mp2 creation.
    I read some posts in this forum and that sounded like the best combination. I am not satisfied with the results. All the mp2 files I create have a sort of static hiss (like fuzz) and are tinny in some spots. The sound is okay on lower volumes but as soon as you turn it up a bit the lack of quality is very apparent. I am thinking that this is not right since you should be able to get near perfect audio from a DVD source.
    Any assistance would be greatly appreciated
    Thank you
    MDK
  2. Ok I know this is an old post but I'm getting the same problem and haven't been able to find any solutions on the board...does anyone have any idea?
    I'm using the rip/encode without 8gb free tutorial ripping an svcd
  3. Some Dvd's can be tough to rip correctly. I've had problems recently making a back up of my movie shrek. To overcome the audio problems I used vstrip and demuxed the ac3 out of the vob. I then used ac3decode program to convert the ac3 file to wav. I used smartripper2.36 and set it up to rip the video stream only from the vob's and used dvd2avi then to convert your new vob to d2v file. In Tmpgenc i then combined and encoded the d2v and wav files to make a vcd mpeg file. It worked beautiful. Maybe this will help in your case.
    To legally make a backup of a dvd you must own the dvd.
    QLD Ozwegia
    Hi MDK,
    Just a thought but are you making SVCD to play on stand alone player? If so then downsampling can be a waste of time. Most dvd players that play SVCD will run the 48k track no probs. At 224 kbps this could be a bit wasteful though. I've done several rip/converts using 192kbps and 128kbps (CD qual) at 48k with excellent audio quality. It's just a shame that no stand alones support multi channel audio SVCD decode or i'd use the 224 kbps and 5.1 channels. SVCD playback will only be at 2 channel or surround at best. Look at DVD2SVCD as an alternate package. It uses toolame for audio and is a nice one step rip--->svcd option.
    Regards
    Studebarc.
