Ok.
Put in a dvd and open it with dvd shrink then when it starts to analyze it, a copy protection error comes up "no dvd sessionkey was found".
Should i use dvd decrypter instead ??
Results 1 to 11 of 11
You shouldnt have to.
Try using decrypter to put it on to your HD first and see if that fixes it.
Is the problem with all movies or with one in particular? -
It's with all movies I have tried . I use dvd shrink v2.3 and it's a free license. ???
Am I missing something here ?
Here is the whole error message "copy protection error, no dvd sessionkey has been establish" -
here is how I do it:
insert disk into dvd drive
let disk play on win DVD for a few sec.
then open disk with dvdshrink 3 beta 5
next I use the deep analisys option
then I reauthor and backup
finialy I burn with nero
I have never had a problem with this method every disk I've done has played flawlessly. -
Hi all.
Draven, as Grant_H suggested, you should try DVD Shrink v3.0 beta 5.
Here are a few guides to get you going:
http://www.dvdshrink.info/guides.php
Let us know how you get along. -
You're welcome.
I have done quite a few ripps with both ver 2.3 and 3beta5 now, and never had that problem. I never play the disk at all either, just put it in and open shrink and go to work!
What O/s are you running, I use 2kpro on that system. Also I have power dvd installed, not that it should probably matter. -
can any one tell me why i cant reauthor with dvd shrink 3 beta 5, if i select reauthor it doesnt show the files to drag and drop but they are there in version 2.3
Newbie Help Needed for making Videos
By stroke in forum Newbie / General discussionsReplies: 8Last Post: 6th Mar 2011, 07:42 -
Newbie Question on bluray to -R backup.....
By titot4u in forum Blu-ray RippingReplies: 44Last Post: 20th Nov 2009, 19:47 -
Problem making backup of The Dark Knight Region 2 DVD
By soneman in forum DVD RippingReplies: 4Last Post: 14th Dec 2008, 15:48 -
Newbie, advise for easy 1 step backup of dvds
By mbogda in forum Newbie / General discussionsReplies: 5Last Post: 4th Sep 2008, 13:18 -
Newbie making good progress with 1080i content needing expert advise
By djdrock in forum Video ConversionReplies: 20Last Post: 27th Jun 2008, 11:01
