  1. Member golfnut's Avatar
    Sep 2003
    Currently using latest version of Power DVD for my DVD Rom. Is there anything better out there? The only requirements I have is that it must be DTS and DD compatible and work with Windows XP. Thank you for your suggestions.
  2. Member adam's Avatar
    Sep 2000
    I think PowerDVD and WinDVD are the two most popular. See if you can find a demo of WinDVD and see if you like it better, I actually do prefer it. The version I have supports DTS and they all support DD. I run win XP also.
  3. Member golfnut's Avatar
    Sep 2003
    Thanks Adam, I will give WIN DVD a try.
