Nowadays a lot of people use Proxy server to post message onNewsgroup.
I am wondering if anyone know how to trace a user's real IP address that is hidden behind the proxy server ?
thanks
Results 1 to 12 of 12
if its an anon proxy -- no , unless you have
access to it in person or via remote
generally speaking anyway ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Try this free program (NeoTrace) that gives you a graphical trace. It's the freeware version of one that law enforcement has used for tracing. Try it with an ISP in another continent and you may be suprised at the route the signal takes. Very educational. If someone uses a proxy, it will only report the proxy address, but you will be partway there. (http://www.networkingfiles.com/PingFinger/Neotraceexpress.htm)
http://visualroute.visualware.com/ does exactly the same thing also (mentioned in list above) , and its free ..
Err its not free... trialware..
the online is free ...Originally Posted by RabidDog"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
After you trace the IP with some of the websites mentioned above, then you may still want to know who is the person behind the IP number and figure out why they are contacting you. Your can find out by running an SPAM & search includes: Current phone number, address, address history for 30 years, age, birthdates, household members, relatives, associates, property ownership, lawsuits, marriage, divorce, criminal records check, sex offenders, terrorist watch, bankruptcy, tax liens, and more stuff.I am wondering if anyone know how to trace a user's real IP address that is hidden behind the proxy server ?
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator redwudz -
pilott, please don't dig up old topics to post in. Read our rules before posting.
If you do a 'whois' of a domain name/website/IP address, you will just get the registered owner of that site, along with it's listed location, not necessarily the person who you are looking for. For example a 'whois' of a AOL address won't give any info on the 100,000+ members that use the service. And all the information that site you list might give you is a matter of public record and there is no guarantee there is any info available there beyond basic information that can be obtained freely.
How to trace original ip address of email sender?
By skorpinok in forum Off topicReplies: 1Last Post: 24th Jan 2012, 00:28 -
Some Problems in PgcEdit --Trace Mode--
By dashali in forum Authoring (DVD)Replies: 1Last Post: 22nd Mar 2010, 16:28 -
uninstall every trace of any video codec
By greendesert in forum Software PlayingReplies: 8Last Post: 20th May 2008, 11:27 -
Video Files have a trace effect
By pbisaillon in forum Authoring (DVD)Replies: 7Last Post: 18th Oct 2007, 13:05 -
Changing my IP address?
By Akabane Kurodo in forum ComputerReplies: 24Last Post: 7th Jul 2007, 09:28
