I've got this XviD video which won't load in TMPGEnc. Not a problem I think to myself, this has happened many times before. I'll just frameserve it through VirtualDub and that'll fix it... it always has in the past.
Not this time! The signpost file gets rejected by TMPGEnc as well.
What do I try now please?
Results 1 to 19 of 19
Are you using Virtualdub MOD? Could the vid have vbr audio? I understand Vdub mod handles that. :c)
There's no place like 127.0.0.1
The Rogue Pixel: Pixels are like elephants. Every once in a while one of them will go nuts. -
No. I'm using the bog standard v1.5.4 of VirtualDub.Originally Posted by Gees
The video does not have VBR audio. The only thing slightly unusual about it is that the audio is completely uncompressed - ie. PCM @ 44.1, 16 bit, 2-channel stereo.
The only other thing I've noticed is that VirtualDub identifies the decoding codec required to be XviD whilst AVIcodec says it was encoded with a DivX 5 variant. -
Hmmm. I don't know what it could be then. Sorry. But someone will know. :c)
I use Gpot to check the few avi files I've worked with and it shows whether you have the necessary codecs. I've never used "AVIcodec" before.
I know there was a recent new Divx5. - 5.1. Perhaps that will handle the variant?
Perhaps this thread will help? https://www.videohelp.com/forum/viewtopic.php?p=667927#667927There's no place like 127.0.0.1
Thanks for trying to help. You might wanna take a look at AVIcodec if you have time. I started off with GSpot too, but found AVIcodec to be superior, so I changed over.Originally Posted by Gees
I have Dr. DivX 1.0.2p & DivX 5.1 already, so that isn't the problem either.
I have had much success with the VDub frameserver in the past and nothing serious has changed with the config of my computer recently. -
I can't help much, but you could try frameserving with AVIsynth. Even though it has a steep learning curve, I would not think it would be hard just to do a straight-forward frameserve. Or you could try some of the other frameservers in the tools section.
"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune -
There are few things you can do to try to solve the problem.
1. reinstall the handler on vdub
2. change the audio to wav audio
3. use the fourcc changer availble in the tools section to change the avi
from divx5 to xvid.
4. make sure the direct show reader in the environmental settings of
TMPG is set at 1 or 2.
To Gees, the avicodec can also handle mpg1 and mpg2 files. It will give you their characteristics such as frame rate, resolution, audio and video bit rates, etc. -
Thanks LaddyDaddy. :c) And DRP for mentioning it in the first place. Don't know how I overlooked it all this time! :cD I've only ever come across Gspot mentions in the past.To Gees, the avicodec can also handle mpg1 and mpg2 files. It will give you their characteristics such as frame rate, resolution, audio and video bit rates, etc.
Now a part of my arsenal. ;c)There's no place like 127.0.0.1
I just told someone else this but I'll do it again.
Open file in Vdub, set full processing mode for audio and video
start frameserver.
Open the signpost file with another instance of vdub and get
the video info. it should be PCM and uncompressed video.
If so , how can TMPGenc complain about that ? -
I've tried all these things and no go. I've installed the new v1.5.5 of VirtualDub as well but it made no difference. When I play the file (which the computer does just fine), WMP reports DivX being used as the decode filter. The fourCC code is also set at DV50. It seems that VDub is incorrectly identifying the file as XviD for some reason.Originally Posted by Laddydaddy
The DirectShow filter is already set at #1 priority. -
I've done this and yes the second VDub does report both uncompressed video & audio but TMPGEnc still won't accept it as input.Originally Posted by FOO
I've noticed a couple of new things myself. When opening the file in VDub I get "Error decompressing video frame 0: An unknown error occured (may be corrupt data). (error code -100)". VDub cannot play the file at all.
I ran it through VDub-Mp3 Freeze as well and every single one of the 5162 frames is reported as being corrupt, yet the file plays perfectly in WMP.
Someone with fewer brains than me has obviously mucked around with this file at some time to solve an audio sync problem because the framerate is 25.003fps.
Any further help or suggestions anyone can offer would be greatly appreciated. -
hmmmm...
This is a long shot. Vdub complains about frame zero. Start frameserving from, let's say, frame 10. If the first or first few frames are problematic maybe you can skip them. See if TMPG will accept the file if you start frameserving from something other than frame zero. -
Red Herring.VDub cannot play the file at all.
We have all been working on a frameserving problem all this time
and NOW we find out Vdub can't read the file to start with.
"We don't need to worry about those pesky error messages, they just put those in there to piss us off. Let's ignore them and continue anyway"
Have you noticed ?
Most of the posts on this forum about impossible problems originate
from downloaded Xvid or Divx.
Why don't you guys get wise ? -
If it's XVID, would changing the Four-CC do anything, or am i just pretending to know more than i actually do?
Are you actually trying to help at all or are you just editorialising for the hell of it? Can I assume you have nothing constructive to offer?Originally Posted by FOO
Sorry no, I have nothing constructive to offer.
I decided yesterday to boycott all Xvid problems.
I don't have any to experiment with, so I can't learn anything.
You have to admit I tried.
Good luck with your problem
Can't get XVID to work, Vdub+Moviemaker errors
By nhgawe in forum Newbie / General discussionsReplies: 1Last Post: 10th Apr 2010, 20:39 -
What is a good AVI joiner (freeware I hope) for when VDub won't work??
By Lolipop Jones in forum Newbie / General discussionsReplies: 1Last Post: 5th Jan 2010, 10:52 -
VOB file won't process in VDub
By CursedLemon in forum DVD RippingReplies: 3Last Post: 17th Sep 2009, 17:35 -
Can't get Xvids to work in VDub
By clos in forum Video ConversionReplies: 3Last Post: 9th Jul 2007, 12:47 -
Autoplay on PC won't work now
By gwoiler in forum Software PlayingReplies: 3Last Post: 31st May 2007, 16:36
