Closed Thread
  1. I have borrowed "Jackass the movie" dvd and I was trying to decrypt it but it came up with the message:
    "Media region code is mismatched to logical unit region!"
    It says in the same box to go to www.firmware-flash.com for region free (RPC Phase 1) Firmware. The region is 4 but I live in Australia.
    It also comes up with:
    "The Slower 'Brute Force' VOBDec/DeCSSPlus will be used instead I/O Key Exchange"
    What do I need to do, should I go to the website I mentioned or is there a way around it?
    You are in breach of the forum rules and are being issued with a formal warning.
    / Moderator flaystus
  2. Originally Posted by Luke23
    That means it will use another method to ripp the movie.
    Just continue the operation dont worry about it.
    Isn't it illegal to rip borrowed discs?
    You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
  3. It only let me decrypt 4% of the movie.
  4. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    This side is provided to help you backup movies you own. Not movies you downloaded or rented.
